Hi!
My win vista stopped working, so I decided to install the Win7RC (64 bit).
Before the vista crash, the battery care function was turned on, but when I installed the vaio control center, at the power management part I can't see the battery care function, so now I can't charge my battery over 80%
Is there any solution, or is this issue due to a driver compatibility with Win7?
Thank you for your help. 😃
noone can help me? 😞
Hi!
