Dear all
Is there someone who owns this new model? I am contemplating the FW21Z or FW31ZJ and can find the only major differences being the OS 32-bit vs 64-bit and a ever so slightly faster CPU.
Apart from gaining the full memory benefit from 64-bit, is it worth the extra money? Please get in touch on ejrossouw@freeler.nl if you feel you can share your experience with me.
Many thanks
Hi BIGGEST PROBLEM WITH vgn-aw21xy IS THAT 64 BIT IS NOT COMPATIBLE WITH MOST OPPERATING PLATFORMS I AM TOLD A SERVICE PACK WILL BE NEEDED IN ORDER TO WORK FROM 32 BIT 64 BIT IS SADLY TO FAR AHEAD OF IT'S TIME IN THE U.K.ANYWAY SO I CAN'T SEE THE POINT OF SPENDING BIG MONEY AND THEN SOME ON A LOVELY BIT IF KIT THAT NEEDS TWEAKING TO WORK ! ANYBODY OUT THERE GOT THE SOLUTION PLEASE ?
