VGN-FW548F and windows 7 Ultimate x32
brkr
hi, i bought this vaio 4days ago and yesterday installed win7 ultimate x32..And all recovery files have been deleted..now i'm using vaio and there isnt a big problem but some sony vaio softvares can be necessary for me..can you give me advice which products must i install?
Which Sony software programs do you need?
It would have been simpler to UPGRADE to Ultimate - that way you would have retained all software, utilities and settings.
Drivers and Utilities are usually available for download but not Sony Applications.
The only ones available are on the Sony USA website here:-
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FW548F/B&region_id=1
:slight_frown:
brkr
i have tried these drivers but they arent suitable for ultimate :S i couldnt install them 😞
Usually 99% of Home Premium drivers will work with Ultimate.
The only other way you could go is to return your Vaio to Home Premium by tapping F10 during boot and then carry out an Upgrade to Ultimate. This will tell you if any of the existing drivers are not compatible.
:thinking:
