Transistor
VGN-FZ21Z Hard Drive
How do I find out the Hard Drive Type, SATA, Pata and maximum size of drive. I wish to Start-over with a new drive. :slight_smile:
Hi Transistor and welcome to Club Vaio.
It is a SATA drive and all 2.5 inch SATA types (1, 2 or 3) will fit.
There is no limit to the capacity as long as the drive is not thicker than 9.5mm. Some of the newer 500GB drives have three platters and are 12.5mm thick - they will not fit your Vaio. I think Seagate and Western Digital are OK.
Do you have a problem with your present drive? If we can help, just ask.
:wink:
profile.country.en_IE.title
sonypass33
I have the same laptop as you and recently put a 500GB WD5000BEVT in it.
Works fine!
Transistor
Thanks for all your help, much appreciated. I can now fit a new drive with confidence. :slight_smile:
