VGN-NW11S/S driver help
loucypher1
Hi
I have a Vaio VGN-NW11S/S , Running Vista H P  32bit.
Missing a  Sony Firmware Extension Parser driver.
I Have been to the downloads
http://www.sony.co.uk/support/en/product/VGN-NW11S_S/updates
, but cannot find anything relating to the above.
Can someone put me right please
Hi Loucypher1,
If you go to the link you have given in your post and click on 'Preinstalled Drivers and Utilities' -> 'Microsoft Visa' you will find the 'SFEP Driver'.
This will need to be installed from within Device Manager using the 'Have Disc' method to install manually.
Hi Loucypher1,
loucypher1
Hi Blencogo
Many thanks for the reply,& info.
All sorted
Once again thanks
