Can anyone get the keyboard + pointing Device + display working properly working in vista?
As my keyboard FN key does not work
I can't auto scroll any more (found a small work round using driver from VGN-C1S/G to get
the mouse working)
Sony had said they will released all driver by the end of March 2007
And now it April and none of the update work with my laptop
So I think I have to go back to xp unless you lot can help
please some help as i love work with my vaio and vista at is min look cool ( that is to show of :smileygrin: :smileygrin: )
as you can't show of with a hp can you now
Hi die0u0die and welcome to Club Vaio.
All the Vista Applications and Utilities for the S4M seem to be available here -Vaio-Link VGN-S4M DOWNLOADS
To get the Fn keys working you need to download and install IN THIS ORDER:
1. Sony Utilities
2. Sony Shared Library
3. Vaio Event Service
4. Setting Utility Series (in the 'Other' tab)
The nVidia GeForce Go 6200 Vista driver does not seem to be there. I think you can use the nVidia Go 6200 video driver at VGN-FS215S Vista Downloads - the pointing device driver is also there!!
ok i'll test it out and let you know
Ok keyboard FN keys are work
But the display drivers don install at all
Plus the update does work else well
(http://www.vaio-link.com/vu/error/error.asp?l=en&p=index.asp&e=novuax )
Any help
I didn't need to install nVidia drivers for my Go 6200; Vista did it automatically. You could try updating the driver and letting Vista search for one.
The drivers that vista gave do not have the full functionality like the orignal drivers, that's y i need the orignal drivers.
Plus does anyone knows how to fix the update problem
