Hi
My Sony vaio VGN-TX5XN/B will not work with battery in if I remove the battery it will boot up. If I then insert the battery it states that the bettery is charging but it isn't. The amber battery light also flashes I have tried the battery in my friend laptop and it works fine. Please help?
Jean
