VGX TP3Z wireless keyboard edge motion how to disable
Michelsz
Recently bought a vgx tp3z and I am extremelly annoyed by the edge motion feature on the wireless keyboard.
The touchpad is really small and as soon as you move your finger too close to the edges, the poiner moves itself. this causes a lot of grief and wated time on wrong clicks. It really spoiles the usability of the product.
I am about to give up and bring back the system to the shop.
Is there a way to disable this feature ?
0 REPLIES 0
