Hello,
I need your help for my VGX-XL201. I'm going to buy a 2nd HDD Samsung F1 320 Gb and I want to make a Raid 0 installation but I don't know how! I have a Raid0 system on my "normal" PC with a motherboard Asus. And it was very simple to create. On the VGX's Bios the only option that I see is to "SHOW" raid system at the starting. And when I turn on this option, I can see after the logo "Intel" a 2 lines of text but I can't access to a Raid menu who can give me the possibility to create the raid. Maybe I need to press a key but I can't see anything, the screen change too fast for read it.
So, can you tell me how create a Raid0 configuration on my VGX ? Does I need the recovery CD to create or just activate in the startup menu?
Thanks for your help!
assume you have already done this, but, just click the option to configure raid during the boot. its fairly easy. I have mine configured as RAID 5
