VIAO HDD PARTITION
Thalamus.
Champion
Hi Dave,
welcome to Club Vaio.
Here is Sony's official guide , when you get to option 10 select C & D recovery (change partiton size)..
Note following this guide will delete everything on your Vaio's HDD, then re-install the original OS and pre-installed applications. Therefore make sure you backup important data first.
There are also third party programs such as Paragon Partition Manager which you could use..
Alternatively you could move your My Documents folder from it's default C drive location to the D drive, use this link for a guide on how to this: Change the Default Location of the My Documents Folder
dave333
Thanks Thalamus - very easy to resolve when pointed in the right direction!! Working well at the moment - just have to remember these useful hints. Regards, Dave
Thalamus.
Champion
You're welcome Dave, glad I could help.. :slight_smile:
