Hey guys I have a very important question.
I've bought a VAIO 2 years ago and now I have to intall the whole system again, because it can't find the OS, but my Recovery CD's don't work.
Do you now where I can order new ones from the VAIO-Support?
It's really important, because I need it for my Job and I can't find anything on the support site.
PS: My English is bad, but I hope you understand what I want to tell you.
Greetz
Dani
Hi Dani,
Did you create the recovery disc's or were they supplied by Sony.?
If you created the recovery disc's yourself then your vaio has a hidden recovery partition.
Start your vaio and when you see the Vaio logo press the F10 key repeatedly this normally would start the recovery process..
If that does not work or your disc's were not supplied by Sony then you will have to contact Vaio-Link to purchase a new set of recovery DVD's..:smileysad:
