I have installed W7 pro on my viao after wiping the hard disk. Can anyone suggest where I can find software to help me run the mode buttons and use Fn5 and 6 to lighten/darken the display?
I am just a user, not any sort of IT expert. I just want to be able to use the functions that I have got used to!
Message was edited by: basunwin
Solved! Go to Solution.
Hi basunwin and welcome.
Sony do not fully support Windows 7 on your model but reinstalling the Vista utilities should work.
Go to the Support website for your model here: -
http://www.sony.co.uk/support/en/product/VGN-SR19XN/updates
Go to the section 'Preinstalled Drivers and Utilities' and download and install the following in order: -
1. Sony Shared Library
2. Setting Utility Series
3. Vaio Event Service
Then install the Update for Setting Utility Series to be found in the Windows 7 section.
Sony advise that you reinstall all these utilities - your choice.
Good Luck.
Good Luck.
