Vista Moduslink Express Upgrade => Ultimate?
pecany
I missed Windows XP Fax programm after Vista upgrade...
Hello,
I bought my 2nd VAIO (a VGN-FE28H) in December 2006 and shortly after that date I ordered that "Vaio Moduslink Express Upgrade for Vista, Home Premium". Vista is fine, but soon I missed the Fax programm!! Because I need it and it is only included with Vista Ultimate, I additionally bought that version. The question now:
How shall I install it?
1. Over the existing Moduslink-Express-installation? (I fear I could get problems...)
2. Or should I first install Vista Ultimate and then ONLY apply the drivers CD #2 and the applications CD #3 which I have from the Moduslink-Express-Set, so that I again have all drivers etc. up-to-date?
Thanks in advance & Regards!
kee-lo_
The second idea is probably the best, make sure you keep a copy of all the drivers from www.vaio-link.com too
pecany
Just want to report that it (second way) worked! 🙂
kee-lo_
Glad to hear that!
