Vista Ultimate on AR21M - Camera Problem
W33ALH
Hi All,
First of all, thanks to all the guys on here that have posted their experiences of installing Vista on their VAIO's. I have used many of the tips to set up my AR21M
So have have a done a clean install of Vista Ultimate on my AR21M and I gotta say, it is really sweet, I'm loving it so far.
However, I cannot get the camera to work and have another couple of missing devices
Here's a snippet from Device Manager
I wonder if anyone here has any ideas what these are - everything seems to be working - granted I haven't tried a mem stick yet - any help would be appreciated
Thanks in advance
7 REPLIES 7
Jshrk
Hey Ive got exactly the same problem anyone found out what those devices are or how to get to work?
michael81
Hi folks,
you best check out these two sites:
Driver Compatibility Overview
Sony UK Driver Site AR21M
If you make sure that all appropriate drivers are installed, there should be no more unknown devices.
i think you should install all drivers manually, then you are uptodate on your complete system anyway.
Good Luck! Michael
W33ALH
appreciate the links but I've been through these already and i still have two missing plus the camera - the tv tuner driver got rid of the unknown multimedia device
still no joy with the camera - its a nightmare tbh - i use a webcam all the time
clivus
Hi. I also have an AR21M, but my only problem is the Webcam is missing despite re-installing the XP drivers for it. I did get a reply from Sony on the subject that pointed me to a hotfix from Microsoft. However the file isn't there for downloading, apparently you have to phone Microsoft first which I simply haven't had time to do. I'll see if i can find the link again and post it later, perhaps somwone else will have the time to contact Microsoft.
clivus
Hi again. Found the link, no idea if it will work but if you've more time than me then please let us all know.
NOTES 09-Apr-2007 Action Type: Info
Thank you for contacting us.
Please go to the following web address and follow the instructions.
[][http://support.microsoft.com/kb/931812 | http://support.microsoft.com/kb/931812]
Regards,
Sony Vaio Team.
I can find the MS Hotfix KB931812 download (attached below) but I don't think it will work without an update to the Vaio Camera Utility which will hopefully arrive later this month.
Try it if you are brave!!!
:thinking:
W33ALH
thx guys - I have tried to resolve using the hotfix and it is still the same unfortunately
blue screen on the cam utility
we'll get there eventually, somehow...........sometime........... :tongue:
