VISTA UPDATES FOR-PCG-K215M
profile.country.de_DE.title
sibanwo
Hi guys, pls where can i get vista drivers for PCG-K215M. :thinking:
Sony do not provide Vista Driver and Utility upgrades for any of the K-Series Vaios. They only support Vaios up to a few years old.
I'm sure you can install Vista on your K215M but it will be painfully slow and I don't know if there are Vista drivers for all hardware - if the Vista inbox does not support everything, you are going to have to search for a working driver. I would worry about finding a Vista graphics driver for the ATI Radeon IGP 345M. RAM is also going to be a problem as the graphics will need a full 128MB of it to run Vista and you can only put a maximum of 1024MB in the Vaio.
That said, I'm sure it has been done but not with Sony support.
:slight_frown:
