Hi!
I have read all recommendation in this forum about the non-responding hotkeys for brightness, volume and so on. The thing is that I can still not get the volume hotkeys to work, all other hotkeys works just fine. I do see the volume indicator when I press the hotkey, but it wont affect the sound at all.
I have reinstalled the utils.exe (more than once - just in case repetition will do any good)
The systeminfo: Vaio PCG-GRT996VP, XP sp2
Regards,
N
Thanks for your reply, but I must have missed something. What is the difference between the "Utils.exe" I mentioned in my post; the utils.exe I've downloaded from "vaio-link" - "drivers and patches" - "utilities", and the vaio-utils that you´re talking about?
VAIO Link usually has a more up to date version
