I am having problems with my volume control of my FE21B - The mute button only has an effect when it is held down when I am not in the window of Itunes / Media Player. Also I recently changed back from XP Pro to the factory Media Center Installation and noticed a luminous green volume bar and mute message when the volume buttons are used. In XP Pro this was a nice black box much like when function buttons are used; brightness for example...does nayone know if there is a way to get the XP look back and how to fix this mute button issue??
Cheers,
Matt
Anyone...?
