VPC-EB3E4E / W AND VPC-EB3E1E / WI? POWER SUPPLY WORKS FOR BOTH?
profile.country.es_ES.title
antanist
Hello and thanks in advance for the support, the question its:
Does the power supply for an VPC-EB3E1E / WI  works properly for an VPC-EB3E4E / W?? im going to buy an original power supply from the store but the list of compatible hardware does not shown the 4E version only the 1E, thanks !
rich912
Hi antanist,
Presumably you have the original power adaptor? If so, and most importantly, have a look at the lable and check that the output voltages are the same for both (probably 19v).
Secondly make sure that the output amperage is equal to or greater than the original adaptor. If it is less you will damage the adaptor and possibly your machine, if more the machine will only draw what it requires.
Rich
Go n-éirí an bóthar leat
rich912
Hi antanist,
Rich
