VPCCB2S1E/B drivers for win8
profile.country.el_GR.title
jordanius
hello.I have just installed windows 8 in my vaio and i have problems with some drivers.i cant find the drivers for the fn buttons like brightness.for windows 7 the problem solved with vaio utility.also i cant find the driver for the graphics cards in order to switch between them.does anyone can help me?thank you
Hi jordanius and welcome.
It is my understanding that the drivers provided by Sony are to be used following a MIGRATION to Windows 8.  The new installation relies on software/drivers from within the Windows 7 installation so you MUST choose "Keep Windows settings, personal files, and apps" during setup.  A clean install is NOT supported.
That said, have you tried installing the original Windows 7 preinstalled version of 'Sony Notebook Utilities'?
Drivers are still being added, so I would keep a close eye on the Support page for your model.
:thinking:
:thinking:
