VPCEA AHCI BIOS Option for SSD
profile.country.de_DE.title
JSchmid2
I'm  using a SSD and always at restart there will be the message "No  operating System found". Then I have to do a restart (strg+alt+del) and  after that it works. I read that the ACHI mode in BIOS should be enabled to  prevent this problem...
But in the R0300Y8 BIOS it is not possible to activate the AHCI. What can I do?
profile.country.pl_PL.title
rafmart222
Have you foung the solution?
Rafal
