vpceb1soe upgrade from i3 to i7?
profile.country.es_ES.title
alimacca
Hello,
Is it possible to upgrade from an i3 to an i7 processor in the vpceb1soe model? Also, would it be worth it cost wise and is it it a straight forward operation, or does it require a pro?
Many thanks in advance!
I suppose everything is possible but I don't think it will be very cost effective.
The newer SandyBridge processors will not fit so you would have to find an Arrandale processor - the fastest available is probably the Core i7-640M @ 2.8GHz.  The RRP is just under £500 but you can find it discounted at around £270.  Fitting may cost £100.
http://www.kikatek.com/product_info.php?products_id=174097&source=froogle
I'm not exactly sure which socket your Vaio has, 988 or 1288, so you would need to check.
Personally, I don't think it is worth it and it may bring more problems than advantages.
I would leave well alone.
:thinking:
:thinking:
