Hi. I bought sony notebook, model VPCEE2E1E. The software for bluetooth was installed, but when icon double-clicked it doesn't work. I switch on wireless and wireless connection on internet works but bluetooth.
I would be grateful if you could advice me how sort this problem out.
Thanks.
Solved! Go to Solution.
Hi k_nijat,
welcome to Questions & Answers..:smileyhappy:
Unfortuantely according to the specifiactions of the VPC-EE2E1E you vaio does not have bluetooth capabilities..:smileysad:
If you want bluetooth on your vaio you'll need to purchase a bluetooth dongle, there are micro dongles available something like the Iogear GBU421 or the Kensington 33902eu
If you buy a USB blue tooth dongle make sure it is Windows 7 compatible..
Check the specifications sheet that came witth your Vaio.
I do not think the VPCEE2E1E has a bluetooth radio device fitted.
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VPCEE2E1E_WI&l=en_GB
Hi k_nijat,
