My all-too-new laptop having had an unfortunate coming-together with a hard floor, it needs a replacement screen - which I'm confident enough to do myself. But I can't take out the broken screen because I can only remove the top two screws (at the top right and top left of the display). It looks like there are two further screws at the bottom right and bottom left, but these are hidden behind the hinges. Is there a simple trick to accessing these, or will I have to remove all manner of other bits first?
Thanks for your help.
Chris
Message was edited by: chrlovel
Solved! Go to Solution.
That's brilliant! Thanks, Blencogo
