Web button
bikeit65
Web button
Hi all Just received my new Vaio laptop which has a web button to load the internet only, so when my laptop is switched off and i press the web button to launch the internet only does my antivirus programme also load or am i unprotected while on the net?
Tags (3)
Hi bikeit65.
As you cannot download anything and cannot access the Windows partition using Quick Web Access you do not really need an anti-virus program as a virus cannot install itself on your computer.
Anyway, it would defeat the object of a quick loading browser.
:wink:
Hi bikeit65.
:wink:
burghbhoy1969
how do you update the browser in this feature.
it`s no longer supported and you can`t download using this so how do you update the browser ? :thinking:
Hi burghbhoy1969
Any update to QWA would need to come from Sony via a Vaio Software Update.
However, I don't think I have ever seen an update for this feature.
:thinking:
