Hi all,i just registered with VAIO and i really need your help with smth;i`ve got a sony notebook,model vgn-fj3m/w,the one that has its web cam incorporated and everytime i try to use it,it says "not connected".
Could u pls help with ideas of how to fix it?
Welcome to CV,
Are you running XP or have you upgraded to Vista?
If vista then update for the camera utility is here
