Hi Forum
I am looking at buying a Docking Station for my Vaio VPCSB1V9E, Sony show 2 models of docking station in the accessories section of the site but which one is correct for my Vaio VPCSB1V9E.
Robert
Solved! Go to Solution.
Hi rhoggan.
You need the VGP-PRS20 for your model.
http://www.sony.co.uk/product/vaio-docking-stations/vgp-prs20/compatible-products#tab
There is a very good deal at PC World at the moment! - £69.97
Hi rhoggan.
thanks Blencogo
just one more question will this unit handle the new vaio 15" S as well
thanks
robert
Hi Robert
No - the VGP-PRS20 and VGP-PRS30 only fit the 13.3 inch S-Series Vaios.
For the 15.5 inch VGPSE and SVS15 models you need the larger VGP-PRS25 and VGP-PRS35 docking stations.
The only universal docking station would be the separate USB connected model VGP-UPR1 but I don't know if it is still available.
