What is an optical out for on my laptop and how does it work and why is there a red light?
is it nok to have the light on all the time even though im not using it or should i disable it?
One LED will make very little difference to power consuption and there will be no power loss through the output as it is not connected to anything so i really wouldn't worry about it. Probably only affect the battery by 1 minute max from a full charge.
The red light is the way the data is transfered optically, the beam is passed through the optical cable, it is a bit like a normal jack out, there is always an output, but you only experience it when you connect a device, hence the light is always on.
[if you go into an electrical store you may be able to get a rubber plug/gromit that can sit in the hole while not in use]
