Hello!
I have a Vaio VGN-TT11 VN/X and it came with Vista Business 32bit
Since it has 4GB of RAM I decided to change to Vista Ultimate 64bit.
I had some troubles with drivers at first but it looks like thats ok now.
My question is how I can get my previously installed Software back. What I really need is the fingerprint software and the webcam software
Can you download those somewhere?
The drivers are already installed but I can't use the fingerprint scanner or webcam without the software...
Thanks!
edit: would also need the touchpad software, its working but I can't change anything 😞
Hi mk23usp and welcome.
Not all software is downloadable for copyright reasons but you will find the original 32-bit versions of: -
Fingerprint Sensor Driver & Protector Suite QL
Pointing Driver (Alps)
here http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=VGN...
You will probably find 64-bit versions of the Fingerprint Sensor (UPEK) and the Pointing Alps drivers here: -
http://www.vaio-link.com/os/vista/64bit/
