Where to find Vaio Event Manager?
thechud
I have reinstalled Windows 7 and my hotkeys aren't working. It seems the Event Manager controls these but it is not on my list of services running on my computer and I can not find it in the list of  drivers on the Sony website.
My model is VPCCA3E1E
Mark
Message was edited by: thechud
rich912
Hi thechud,
The utilities that control the Fn keys vary between models but with the VPCCA3E1E it would seem to be as follows:
1.    Install the SFEP driver from within Device Manager (this should only apply to a clean install and will be evident as a yellow warning symbol will be shown against the Sony Firmware Extension Parser Device – Human Interface Devices)
2.    Install Sony Shared Library.
3.    Install Sony Notebook Utilities.
http://www.sony.co.uk/support/en/product/VPCCA3E1E_P/updates
Sony does not guarantee that all hot key functions will work if you have clean installed a retail version of the OS.
Rich
Go n-éirí an bóthar leat
