Which function key resets to the 'as-built' state for models PCG-161M and PCG-1B1M?
pictstone
When booting, which function key resets the OS to the 'as-built' state for models PCG-161M and PCG-1B1M?
Tags (1)
Thalamus.
Champion
i pictstone,
welcome to Questions & Answers..:smileyhappy:
When you see the Vaio logo press the F10 key repeatedly.
FYI the PCG-161m is not your VAIO's model number that is  the chassis number, your actual VAIO model should be shown on the  lower right hand corner of your  screen's surround..:smileywink:
https://www.sony.co.uk/discussions/servlet/JiveServlet/showImage/2-647680-4634/model.JPG
Thalamus.
Champion
i pictstone,
pictstone
Thank you very much, and I'll note the correct model number!
