hi
like 3 weeks ago i noticed a problem about playing video clips which are on websites ...i cant seem to able to play clips maybe it myt be norton blocking it but im not sure ...and i want to see some vid clips
plz help
bianca
xx
Hi Bianca - how's the throat?
First place to check is: -
Start -> Control Panel -> Internet Options -> Advanced
Scroll down to Multimedia and check that there is a tick in the box 'Play Video in Web Pages'
If this doesn't work you may need to update your Flash Player from ADOBE FLASH 9
Also go to Adobe.com and download the free Flash Player.
