Why does the keyboard act as if the Fn lock is on when it doesn't have an Fn lock? Model PCG61311M
Techn0phobe
The keyboard does lots of weird things for about a week - e.g. the back delete key will only delete one character even when it is held down - and then it 'cures' itself for a bit.  I am technically a cretin but even so, I wish I had never bought this machine.
warriorfullight
Have it replaced if you just bought it and have it checked by a technical person. This is definitely a keyboard problem.
rich912
Hi TechnOphobe,
This may very well be hardware related by I would check that ‘Sticky Keys’ hasn’t been inadvertently turned on. In Vista you can check this in Control Panel > Ease of Access Center > Make the Keyboard easier to use; navigation may be slightly different with Win 7.
You could also try a system restore back to a date prior to this happening.
Rich
Go n-éirí an bóthar leat
