Wi Fi Network
snatcher57
Wi Fi Network
Hy everybody,i have just purchesed an RZ422 pc,It already has a network card installed but it is a cable connection.I want to install my Belkin wireless card so my daughter can access the internet through my pc so should i remove the existing card and replace it or use a spare slot for the wireless card
You can do either. I'd suggest if you have a spare slot then keep both cards in. That way you can connect wirelessly when available, otherwise through an ethernet connection. If you are connected wirelessly, then obviously unplug the cable as you don't need it (but leave the card in).
