Hello, I am quite new with my Vaio PCG K215 Z. My question is : to use teh Internet in WI FI mode, do I need to buy an Access Point ? Or the internal modem is able to connect without wire ?
Sorry if the question makes you laugh.
Can someone recommend a good router-modem ?
The internal modem is for (wired) dial-up only. In order to connect using WiFi you will need an access point or a wireless-capable router.
Most people on here recommend NetGear for ease of set up and reliable use. Also, most of those people have broadband. You can use a router for a dial-up connection but it will of course be slow
This site may give you a few pointers.
HTH
Hi Barnabe,
I looked at http://www.vaio-link.com/knowledge/search.asp?l=en , And found this Advice
But I'm Sure others will add more help here .
Barnabe,
Do you have broadband?
Do you have a router already?
of course I intend to use the router con broadband, as soon as I have suscribed a valuable Italian provider.:smileyhappy:
thank you everyone, things are getting clearer. I'll come back with questions about installing the whole gear:smileyconfused: ... later.
