As the question above says, this is becoming incredibly irritating. The laptop will load up from hibernation, and I'll either have to go into the Vaio Smart Network and then slide the wireless to the right, or, more commonly, this icon won't even be available & my only solution is to reboot the laptop.
I have unchecked the "allow the computer to switch this device off" buttons from the Device Manager, for both the Intel Centrino and Marvell Yukon ethernet controller network adapters.
Both are operating the latest drivers. Yes, the wireless hard button on the front is switched to the right as well, and the LED is on. And of course the wireless router is fine - other devices are connected to it with no problems.
Any other suggestions before I sling it out the window?
Many thanks in advance,
Mark
Message was edited by: markhoar85
