- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello
I just got my new Vaio F series today, and I was thinking of getting a universal adaptor for when I need to carry my laptop with me (e.g. Class and stuff) and then leave the Original charger at home and ready for use when I get home.
The one I have been looking at is the Cooler Master USNA 120 http://www.coolermaster.com/product.php?product_id=6739
It’s pretty small and light compared to the one that comes with the Vaio, so it would be great for traveling.
The power adaptor that comes with my Vaio has an output of 19,5V - 7,7 A
Where the one from Cooler Master is 18 - 20Vdc / 19Vdc 5.79A and provides 120 Watt
My question is, if it provides enough power, to keep the Vaio running and charge the battery at the same time?
Or will it not charge the battery but at least keep it from draining?
Or what will happen?
Hope someone can answer my question and thanks in advance.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Unfr4m3d,
A replacement power adaptor should have the same voltage and equal to or greater amperage output provided by the original.
The replacement adaptor you propose may suffer damage if the amperage demand from the notebook is greater than the adaptor is capable of supplying - melted cables or complete failure.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Unfr4m3d,
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It should work with all series since it is universal, right?
_______________
Business is the game!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
_______________
Wrong.There are many definitions for ‘Universal’, one of which is ‘Adapted or adjustable to many sizes or mechanical uses’.
The seller can therefore claim this as a universal adaptor as there are adaptor tips supplied that will fit most manufactures notebooks.
Whether this is suitable for the power requirements of the notebook is a separate issue and in this case possibly not.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm currently looking for a new charger for my NS series.
I've just been told by a well known technology supplier that Sony laptops are nutoriously hard to 'match' with universal chargers due to the laptops not recognising the adapter once it is plugged in...does anyone know this is true?
They said it was all to do with the connection plug etc, i was advised to bring my laptop in so they can test which charger is recognised by my laptop-seems a bit strange?!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I know that Sony vaio laptops have an program that recognize original baterry and doesn„t work with another baterryes like the universal ones....
