Windows 7 and Biometric security
miktidd
I have just updated my Vaio VGN-TX3XP to Windows 7.  Unfortunately the Protector Suite QL that works the fingerprint biometric processor will not work with W7.
Has anyone found a product that will work the biometric coprocessor with W7?
rich912
Have you upgraded from XP or Vista. Your machine would have been shipped with XP but there is a Vista upgrade sensor driver that is worth a try if you have not already done so although I don’t think that it is Windows 7 compatible.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-TX3XP_L&os=7
If that fails to work then you could try installing an update to Protector Suite 2009 which is available on models such as the VGN AW11 amongst others.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW11Z_B&os=10
This should work with Windows 7.
Rich
Go n-éirí an bóthar leat
