Hi all I have a FW31ZJ. I installed Windows 7 clean copy and I was wondering about the drivers available here are we supposed to install vista drivers and then install w7upgrade drivers? Or would it be enough just to install the w7upgrade drivers?
Hi robboli and welcome.
The supplied Windows 7 Upgrade drivers are installable and you should not need the original Vista driver installed first.
However, not all the drivers you need are supplied by Sony in the W7 Upgrade Download and you will need to reinstall the Original Vista Drivers where they do not exist as W7 drivers (Memory Stick, Pointing, SFEP etc).
