- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
windows 7
does anybody have any contact email address for somebody at sony who can answer a question for me ;
when are they going to update there software so i can at least use windows 7 , i had the same problem when vista came out the fact i couldn't use it .
I bought the 64 bit pro version of vista & gave up waiting for the updates to use it & still don't know if there all available, now i've just been on the sony website to see if my laptop is ok to run windows 7 on & low & behold it isn't there on the list .....
rant over .....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Welcome Mr Freeze.
What model Vaio do you have? I'm sure someone here can help you.
If you want to talk to Sony click on SUPPORT at the top of this page and choose to go to the Support Page. Sign in using your Vaio Model and click on the 'Get in Touch' Icon. If your Vaio is out of warranty it will ne a premium phoneline.
If you still have a pre-Vista Vaio then it is most unlikely that Sony will release a set of Windows 7 Drivers and Utilities (particularly if they did not do so for Vista). However, this does not mean you cannot run Windows 7.
Have you downloaded and run the Microsoft Windows 7 Upgrade Advisor? This will tell you what drivers you need to find and which programs are incompatible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
many thanx for the reply , i've got a VGN 21RS i've done nothing to it apart from upgrade the hardrives to bigger ones .
I went on that site but it came back with all soirts on it ;
C:\Documents and Settings\Owner\Desktop\report.mht
have a look & see what you think , obviously i want to keep it to 64 bit but that's been my problem especially with vista it would of let me upgrade to 32 bit but not 64 ............ :smileyd_oh:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry your link does not work.
Can you check your model - VGN 21RS is not a valid model.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry about that VGN AR21S...........
Information about upgrading to 64-bit Windows 7
System Details
Custom installation required You'll need to perform a custom installation of 64-bit Windows 7 and then reinstall your programs. Make sure to back up your files before you begin.
Go online to get important information about installing Windows 7 on a PC running Windows XP
Windows Aero support Your current graphics adapter won't support the Windows Aero user interface. If you want to experience the benefits of Windows Aero, contact your PC manufacturer or retailer to see if an upgrade is available.
Go online to learn more about Windows Aero
Outlook Express This program is no longer included in Windows 7. You can get similar programs for Windows 7 from other software manufacturers.
Go to the Microsoft website to learn more
More info from Sony Corporation Sony Corporation has a website that might give you more information about getting Windows 7 running on your PC.
Visit the Sony Corporation website
CPU speed: 2.0 GHz Your CPU meets the 1 GHz minimum requirement.
2.0 GB of RAM Your PC meets the 2 GB minimum requirement.
176.3 GB free space available on C: Your hard disk meets the minimum requirement of 20 GB free space for 64-bit Windows 7.
Devices Status Details
AVerMedia Hybrid H/W MPEG Card, M115S (DVBT/NTSC/PAL/SECAM)
AVerMedia TECHNOLOGIES, Inc. Unknown We don't have compatibility information about this device.
Bluetooth Personal Area Network from TOSHIBA
Toshiba Unknown We don't have compatibility information about this device.
Bluetooth RFBNEP from TOSHIBA
TOSHIBA Unknown We don't have compatibility information about this device.
Sony Visual Communication Camera VGP-VCC2
Ricoh Unknown We don't have compatibility information about this device.
Bluetooth RFBUS from TOSHIBA
TOSHIBA Free update available The manufacturer provides software to use this device on Windows 7.
Bluetooth RFHID from TOSHIBA
Bluetooth USB Controller (ALPS/UGX UGPZ6XC02A)
Toshiba Compatible This device is compatible with Windows 7.
HDAUDIO SoftV92 Data Fax Modem with SmartCP
CXT Compatible This device is compatible with Windows 7.
Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Intel Compatible This device is compatible with Windows 7.
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Intel(R) 82801GHM SATA RAID Controller
Intel(R) PRO/100 VE Network Connection
Intel(R) PRO/Wireless 3945ABG Network Connection
Intel Corporation Compatible This device is compatible with Windows 7.
NVIDIA GeForce Go 7600 GT
NVIDIA Compatible This device is compatible with Windows 7.
SigmaTel High Definition Audio CODEC
SigmaTel Compatible This device is compatible with Windows 7.
Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Texas Instruments Compatible This device is compatible with Windows 7.
Texas Instruments PCIxx12 Integrated FlashMedia Controller
Texas Instruments Inc Free update available The manufacturer provides software to use this device on Windows 7.
Programs Status Details
Bluetooth Stack for Windows by Toshiba
version 4.00.00
Toshiba Not compatible This version of the program will not work on Windows 7.
Visit the publisher's website for a possible solution
Adobe Photoshop Elements 4.0
version 4.0
Adobe Systems Inc. Known issues You may experience issues running this program on Windows 7.
Alps Pointing-device Driver
version 5.5.7.139
Alps Electric Co., Ltd. Known issues You may experience issues running this program on Windows 7.
Click to DVD 2.5.30
version 2.5.30
Sony Corporation Known issues You may experience issues running this program on Windows 7.
Microsoft Silverlight
version 3.0.40818.0
Microsoft Corporation This program has earned Microsoft's Compatible with Windows 7 logo.
Learn more about the Compatible with Windows 7 logo
Microsoft Visual C++ 2005 Redistributable
version 8.0.56336
Microsoft Works
version 08.05.0818
version 2.0.3001.0
Windows Live Essentials
version 14.0.8064.0206
Adobe Reader 9.1.3
version 9.1.3
Adobe Systems Incorporated Compatible This program is compatible with Windows 7.
Microsoft .NET Framework 1.1 Compatible This program is compatible with Windows 7.
Microsoft Office Outlook Connector
version 12.0.6414.1000
Microsoft Corporation Compatible This program is compatible with Windows 7.
Spybot - Search & Destroy
version 1.6.2
Safer Networking Limited Compatible This program is compatible with Windows 7.
