windows 98 on RXG408
Davetnova
Is it possible to install windows 98 on a RXg408. When I try I get a Dos extender error. I realise that winXX is a dying OS, but this is a school environment and I need windows 98 to run specific recording software that will only run under 98. Newer versions of the software will only run on Macs so I am stuck with the version I have.
Stephanius
Are you certain that the SW you need to run does not function when you use the compatibility mode XP offers?
You can find the settings in the properties of the executable file(s).
Davetnova
The software will noy install under XP the installation ends on win95/98 not found.
kee-lo_
Is there no patch / ugrade / new version available?
