It crashes everytime it opens. Even before it didn't play many Blu ray discs. Is there anyway to fix it? I've found it a really awful programme. Would I be better off buying something else? If so what? How about nero?
Hi ocommane,
most but not all of the pre-installed applications can be re-installed without doing a full Recovery, unfortunately Win DVD is one of those programs that can't...
Have you checked if there is a Win DVD update for your Vaio..
Either by the VAIO Update Utility: double click on the Vaio Update icon in your system tray and follow the instructions.
Or
Via the Sony support download page, Use the following link then select your model in the drop down list to download the update: Sony Support Downloads
Yes, I downloaded the two patches available but both give me the error message "this upgrade can't apply to your version of WinDVD, setup will abort".
