Wireless connection of laptop to a TV
Topdog
Hi Folks
Happy New Year. I have just moved into a new apartment and would like to wall mount a flat screen TV.
Does anyone know if it is possible to wirelessly connect a laptop to a TV. I have a Vaio T1 and it would be great to sit on the sofa and be able to view what is on my tiny screen on the wall mounted TV.
Regards
David
7 REPLIES 7
Hi David,
Have a look at this PC TO TV WIRELESS SENDER
You could also consider a network solution LIKE THIS ONE
:wink:
Topdog
Thanks,
That looks great. Will decide which one to get over the next week.
Regards
avid
kee-lo_
Digisender is supposed to be good too
Dios
Hy blencogo,
it seems that you could help me.
I have a VGN-S5HP and a samsung le27t51B flat tv. The tv has a pc connection that looks like the port i have o the right of my notebook. So, i bought a cable to connect both but i have no image (in fact i have one for like 5 seconds and after this it's gone with the message 'no cable signal').
What can i do, it drives me mad. It works, but not for long...for the five seconds i can see the mouse and a window if i drag it into it.
What can i do? If someone else knows, please help.
Hi Dios,
There is a known incompatibility between some Sony Vaios and some Samsung displays. As far as I know no-one has found a fix yet. It just seems that there is a basic incompatibility.
Have a look at some of the links in THIS THREAD as some people have had success by trying a few things.
This was Sony's helpful reply to the last enquiry: -
"Thank you for contacting us.
Unfortunately there is a compatibility issue with Samsung Monitors.
As yet there is no solution."
:slight_frown:
Dios
Thanks blencogo for the quick answer; i solved the problem by disabling the vaio event service but now i don't find the thread where it is said how to see a movie on this tv.
I get only a black image , not a thing though i can see everything i drag into it only not movies( it was something with.."interlaced"). if you can help "one more time".
thanks.
kee-lo_
