Hello. I have a Sony Vaio 'VGC-V2M' desktop and I want to get wireless internet. The computer has a ‘PC Card’ slot on the side and I was wondering if this is where you put the ‘wireless card’.
Any help would be much appreciated, thank-you.
Yes you can insert a wireless card and get wireless internet. You also need a router to be able to use wireless internet.
Wireless PCMCIA Cards
Unless you're lucky enough to live in Milton Keynes where there's the first wireless ISP
