Wireless Keyboard lights flashing
Glitterx
I have a VGP-WKB12 keyboard.  The 3 lights on the bottom right of the keyboard keep flashing and sometimes when I am typing I get several consecutive same letters eg leeeters.  Can't find any instructions to indicate what I need to do.
Help please.
Glitterx
Hi yes its ok.  No idea why the first battery didn't work though.  Thanks for your help
4 REPLIES 4
jumpsuit
Hi there and welcome to the Community :slight_smile:
Have you tried changing the batteries?
Glitterx
Yes. I think i'll try another battery if its likely to be as simple as that.
jumpsuit
Great, let us know how you get on.
(My wireless keyboard starts flashing when the batteries are running out)
Glitterx
