Wireless Network Connection
debbiemk
I need some serious help here if possible
I just restored my laptop to its original settings and now the blessed wirless network conneciton will not connect!!!!
When I first bought the laptop it automatically picked up the router on my main computer and I was off, now it says there are no networks available!!!!
I have "Local Area Conneciton", 1394 connection and Wireless Newtork Connection showing on the Nework Connections and both the local and Wireless have a red cross on them.
I have been on the main computer looking for help on this, tried what it said about setting up a wireless connection as well as entering my WEP key but it still does not work!!!
Any suggestions please!!!
Before long I will no doubt throw it across the room as I have been trying for about 3 days to get this working!!!
Plase email your suggestions if any to debbie.kirkland1@btopenworld.com
Many thanks
Hi Debbie and welcome to Club Vaio.
I know these things can be a real pain to solve. Can you give us a bit more information? Sorry if they are basic questions.
Model of VAIO?
XP or Vista?
Make and model of Router?
Is the Router set to act as a DHCP Server and is the Vaio set to use DHCP to obtain an IP Address automatically?
Try Run -> CMD and press enter. In the black command box type IPCONFIG /ALL (space between G and /) and press enter. What is the IP Address, Default Gateway, and DHCP Server?
Does it work with a wired ethernet connection?
Is the Router set to 'Broadcast SSID'?
Have you run the Network Wizard?
What Firewall are you using and have you tried turning it off?
:thinking:
debbiemk
OK here goes
Have asnwered you questions as much as I can but I am no computer expert
Hope you can help as this is really doing my head in
Model VGN - FS 4858B
XP
Bt Voyager Wireless ADSL
Router as DHCP ???? Not sure what that is or where
IP address have tried both ways
Config :- Broadcast. IP routing enabled says NO and so does Wins Proxy Enabled
Ethernet adaptor - Media disconnected
Ehternet Adaptor Local Area Connection: Media State - Media disconnected
Both of the above ethernet also have an ip address as well as something about intel
Have run Network Wizard quite a few times now several different ways!
Says there are no networks available
Firewall is off
Many thanks
