Wireless Switch Setting Utility insure (Windows Vista)
I’m encountering a few problems with this software (ver.3.5.00.11270).
Every time I lock my notebook (AR11M, Vista Home Premium express upgrade) I got WiFi disconnected when unlock the user.
This also happens when I switch users.
I’m sure this software is the cause of the problem, because the disconnection only happens if WiFi Switch Setting Utility is running. If I close the software there isn’t disconnection problem when switch users or lock/unlock the computer.
Any solution to this? If I uninstall this software has another way to keep the Bluetooth off and turn on easily when needed?
Thanks in advance.
This is the problem that many people have been finding resently. Here is a microsoft update that sorts out the issue. It has worked for me so far.
Not sure there is a way of turning the bluetooth on and off without the wireless switch. The advice is to keep it off when using the wireless but i leave it on and i haven't had any problems so you could keep it on and stop the switch from running at startup. This can be done through task scheduler.
