Since a total system restore I get the following message when
starting up
" Wireless Switch Setting Utility has encountered a problem and needs to close. We are sorry for the inconvenience."
1)Should I delete the application through start, control panel & add/remove programs
2) where do I find a new version of the software
I am about to install the La Fonera WiFi router and wonder if I have to fix this problem first to amke it work.
Thanks Hans
Thank you
If you go to the Sony Vaio update site, you will find an update for this problem.....
Dear Photoshop Kid,
Very much appreciated.
I will try the Vaio site
Thanks, Hans
