I've bought a VGN-NR10E 10 days ago and was unable to connect the wireless more than once. When I now turn the laptop on, the wireless green light turns on, but as soon as Vista kicks in, the wireless turns off and there is no way to get it working. I've tried actualizing the driver and the device manager says the device is working normally, even though it is not working at all. The helpline has been contacted via email with no answer after 24 hours and still running. Anybody had the same trouble? Any suggestion? No need to tell you, I feel like killing...
Its a vista problem. On fresh install my laptop is the same. Very intermittent.
After windows updates it is ok. So i would recommend that you connect your laptop using a RJ45 cable, and update your windows vista.
