I can not connect my PCG-R600HFP via WLAN using WPA. There is a ORINOCO Wireless LAN Mini PCI Card in it. The option WPA is not available in the WLAN menu. I run WIN XP SP2.
Does this problem come from "old" hardware? Or do I need a driver update or something similar???
Thanks, but the driver I downloaded from vaio-link is dated from Aug. 2001. Pretty old and finally didn't help.
Any other ideas?
Hi tenge,
Is this the file you downloaded?
Wireless LAN Driver
download Version : 7.16.0.189 Size : 0.11 MB Language : All
( 2/19/2003 1:43:46 PM )
Yes, that's it.
Tenge
Yes, that's it.
Tenge
In "Network Properties/ Association Are you saying that DATA ENCRYPTION only has the option of WEP or DISABLED?
If so check out the box above that - NETWORK AUTHENTICATION
One thing - have you checked the box to "Use Windows to configure my Wireless Network settings". If not put a tick in that box.
"Network authentification" has two options: open or shared
"Encryption" has two options: disabled or WEP
The option menu does not change when choosing open or shared
Any ideas?
