XL-301 bluray quadcore
jamflowe
What model of bluray drive can you use?
Does the XL-301 support a quad core cpu?
ITTroll
The BC-5600S is a good option for Blu-ray. See my thread for full details on this mod:
XL201 £100 Blu-ray Upgrade using BC-5600S
The XL301 doesn't officially support quad core. If you install one you will get an unrecognised CPU error during boot. You can press a key to ignore this (every time you boot) and it will continue to boot into Windows. However how stable it will be in long term use is unknown. I wouldn't recommend it.
